General Category => Modifications => Topic started by: threejagsteve on November 25, 2009, 06:52:03 PM
Title: A Lighter Shade of Wail(ing)
Post by: threejagsteve on November 25, 2009, 06:52:03 PM
Everybody knows that compared with the latest literbikes, FJs are about 100 lb overweight. Everybody also knows that a 4-into-1 saves about 20 lb over the stock exhaust, and leaving the centerstand at home saves more.
Of course one can spend about $1000 each for magnesium wheels that only weigh about 6 lb each, but not only is that, I suspect, out of most of our price ranges, also those wheels' ability to survive the first major pothole is questionable.
What are some other ways to trim that unwanted flab?
Just something to talk about...  (http://i48.tinypic.com/m97upg.gif)
Title: Re: A Lighter Shade of Wail(ing)
Post by: Pat Conlon on November 25, 2009, 07:42:06 PM
Go on a diet, work out, and get thee to track school....Your bike will feel 100 lbs lighter.
Post by: junkyardroad on November 25, 2009, 07:56:54 PM
Quotemagnesium wheels that only weigh about 6 lb each
They sure are bitchin though.
Post by: Mark Olson on November 26, 2009, 12:41:19 PM
put more air in the tires ,  it will  make the bike lighter :rofl2:
Post by: Dan Filetti on November 26, 2009, 12:44:49 PM
Maybe if you were to fill the tires with helium?
Post by: Firehawk068 on November 26, 2009, 01:48:08 PM
I use Hydrogen in the tires....... :bomb:
Not only is it lighter..........but it makes you a more careful, and safer rider. :good2:
Post by: threejagsteve on November 27, 2009, 02:10:21 AM
Ooo! A bunch of wise guys, huh?  (http://i48.tinypic.com/2yzkm88.gif)
Here's a small example:
An aluminum rear brake stay arm, weight: 5.8 oz. offset: 5mm on both ends; ought to be just about right for a 180!
(http://i49.tinypic.com/2h6voef.jpg)
Don't have the weight of the stocker handy (mine's in use at the moment) but the offset alone makes it worth the $25 I paid, and it's likely a bit lighter!  (http://i35.tinypic.com/28a1gqx.gif)
Post by: higbonzo on November 27, 2009, 12:26:20 PM
Quote from: Pat Conlon on November 25, 2009, 07:42:06 PM
That is what I always say, "Get Smaller".  Works for me.
Also, the newer sports bikes need to be lighter because they lack the torque in the lower RPM range that the FJ has.  Sure they have 30 plus hp on the fj, but they have about the same torque in their peeks range.  Torque is what make you move, hp is what is used once you get moving.  Actually, the newer sports touring bikes, which is what the FJ is, are actually heavier with the exception of the Aprilia Futura and maybe some Ducaties,and the Honda VF, but they are not 1200 + cc.  And the Ducati and VF are geared way more towards the sports side of "Sport Touring".
Later    :bye2:
Post by: Bill_Rockoff on November 29, 2009, 04:05:57 PM
I'll have to verify with a scale when I take things off for cleaning.
YZF600R rear wheel and tire feels about 5 lbs lighter than the FJ 16" wheel and tire.  Not as light as Dymag, etc. but a lot cheaper.
The factory exhaust feels pretty darn heavy, I thought I remember 26 lbs front to rear versus about 6 lbs for a stainless 4-1 with single muffler.
FZ1 aluminum calipers feel significantly lighter than the cast-iron FJ ones.
I imagine front wheel weight savings would be similar to rear...
So, I imagine I could get my 590+ lb FJ down to a Hayabusa-esque 560 lbs just by completing the typical Modifiers-Anonymous checklist.
FWIW, I don't remember the centerstand feeling quite that heavy - maybe a pound or two.  Useful as it is, I'd just keep it assuming it wouldn't foul the Supertrap stainless pipes I have....
Post by: andyb on November 29, 2009, 04:20:58 PM
According to the scale at the track, my FJ weighs 525lbs (740 with rider), when nearly out of fuel.  So the easiest way to drop weight is to carry less gas around :)
Post by: threejagsteve on November 30, 2009, 11:43:01 AM
I'm 6'3", right now around 180. About the last thing I need is to lose weight. I do work out, to maintain/gain strength.
And I'll be first in line at track school as soon as they start offering scholarships for the unemployed! ;)
Post by: rktmanfj on November 30, 2009, 11:56:48 AM
Quote from: threejagsteve on November 30, 2009, 11:43:01 AM
I could give ya about 30lbs, and we'd both be good...       :empathy:
Post by: ren-dog on November 30, 2009, 06:22:37 PM
I could have listed all the heavy stuff I've removed, but a picture says a thousand words  :sarcastic:
(http://i665.photobucket.com/albums/vv13/ren-dog/th_DSC00397.jpg) (http://s665.photobucket.com/albums/vv13/ren-dog/?action=view&current=DSC00397.jpg)
Post by: Pat Conlon on November 30, 2009, 06:43:44 PM
Hey Steve, I'm just yanking your chain....I'm also 6'3" but a more portly 190...
I have yet to weigh my '84 FJ (T-Ace rear end, FZR USD front end, slipons) but I suspect 510-520lbs.
Post by: racerman_27410 on November 30, 2009, 08:42:49 PM
i have weighed my 86 on certified truck scales... with tankbag and half a tank of fuel it's 527lbs
Post by: Firehawk068 on November 30, 2009, 11:05:27 PM
Steve,
Where did you get that brake stay arm?
it looks like it would work perfect for a 180, and doesn't look like it weighs much either.
Probably a better solution than modifying the stock one. :good:
Post by: threejagsteve on December 01, 2009, 01:08:22 AM
Quote from: Firehawk068 on November 30, 2009, 11:05:27 PM
Snagged off eBay for $25 including shipping. :)
Yes, Fred is running an uncut brake stay arm with a 170 and reports 5.5mm clearance. The 5mm offset on this one means I should have more or less the same clearance with a 180. And at 5.8 oz. I'd guess it's in the neighborhood of half the weight of the stocker.
Yes, that was my thought when I jumped on it. I wasn't even looking for one; just ran across it on my daily eBay scan, the idea light lit up over my head and I hit the Buy It Now.
Post by: threejagsteve on December 01, 2009, 01:24:44 AM
Quote from: andyb on November 29, 2009, 04:20:58 PM
Quote from: racerman_27410 on November 30, 2009, 08:42:49 PM
I think I'm beginning to see a pattern here...  And the vicinity of a 40-lb weight loss ought to be noticeable in every aspect of performance! Thanks!
Post by: ren-dog on December 22, 2009, 10:37:27 PM
I'm a bit bored waiting for the postie's holidays to end  :ireful:
So I decided to remove all the rough casting marks from the con rods.
I did this by using several small 2nd cut and smooth files.
A dremel or some such tools would have been easier.
(http://i665.photobucket.com/albums/vv13/ren-dog/th_DSC00427.jpg) (http://s665.photobucket.com/albums/vv13/ren-dog/?action=view&current=DSC00427.jpg)
Wait saving 5 grams (about 1/5 ounce)  :dance:
Maybe that'll total 25 grams (9/10 of one once) with all four con rods cleaned up.
As for 18 kg (40 lbs) I'll keep looking :wacko3:
Post by: rossco on December 23, 2009, 01:54:19 AM
3 jag
you may have lost weight in between weigh ins   :blum2:
Post by: Pat Conlon on December 23, 2009, 01:52:08 PM
Quote from: ren-dog on December 22, 2009, 10:37:27 PM
Good job, great idea.
Make sure you balance all of them to within 0.3 grams (or less) from each other.
