General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: gumby302ho on August 28, 2014, 08:02:15 PM
Title: Front Brake ????
Post by: gumby302ho on August 28, 2014, 08:02:15 PM
  I was coming back from a ride with my daughter today and didnt figure it out right away but my front brake was fading, I was glad to find out just before we got back home. Now there is nothing, no pressure, no leaks, proper fluid level, everything seems perfect. I am thinking master cylinder piston/cups have failed but I have never seen a master work great one minute then fried the next. Am I missing something........ anti dive  :wacko2:
Title: Re: Front Brake ????
Post by: Tuneforkfreak on August 28, 2014, 08:16:45 PM
Sounds like it's time to take a look see. Weird scenario for sure :unknown:
Post by: ribbert on August 28, 2014, 08:49:31 PM
Quote from: gumby302ho on August 28, 2014, 08:02:15 PM
M/C's can fail internally. That is, no external leaks and full of fluid.
Post by: the fan on August 29, 2014, 05:03:45 AM
I have never had one apart, but could the anti dive be leaking internally?
Post by: red on August 29, 2014, 10:58:28 AM
Quote from: the fan on August 29, 2014, 05:03:45 AMI have never had one apart, but could the anti dive be leaking internally?
The Fan,
I have.  The brake fluid would then be going into the front forks, but only in droplets, not the total loss of brake pressure that the OP has reported.  If a master cylinder seal fails, it can be all at once, as reported.  The most likely cause would be some grit in the brake fluid, causing a leak in the same way that front fork seals can leak, caused by dirt.
A MC in otherwise good condition might be rebuilt with new seals at low cost, or if no seal kits are available,  there are many options for a new replacement.
Post by: simi_ed on August 29, 2014, 11:32:16 AM
It could be the pistons have pushed back into the bore, if you had a steering bump and caused a rotor wobble.  If it pumped back up, that was probably the problem.  Otherwise, I'd guess MC, as others have.
My 2ยข
