General Category => Maintenance => Topic started by: Sabre093 on June 02, 2014, 05:18:02 PM
Title: Small Hiccup while idling
Post by: Sabre093 on June 02, 2014, 05:18:02 PM
I've notice since switching to Supertrapp and having carbs synced I get a little hiccup while idling...low,mid and WFO are fine..i know I can the pipe by adding or re-moving discs..has any one here en-countered this I did not notice this with Kerker 4-1-2 I had on before.
Title: Re: Small Hiccup while idling
Post by: novaraptor on June 09, 2014, 09:28:24 AM
Bump..
Same sort of prob here. Upped the idle a little on my 90, recently cleaned and reoiled the filters. I've been getting a small hiccup at cold idle. I tweaked the sync screw just a little on my #2 and it got less frequent, but still there. Power band seems to be what it should be. I know I should do a resync, but since it doesn't seem broken......
Post by: Sabre093 on June 09, 2014, 09:33:28 AM
I been having problem with choke slider bar...I took tank off and cleaned it and lubricated it and since then it has be ok...I think choke was not closing 100%..and hanging open maybe 3-4%..So far that's all I've done and I think it's sorted out.
Post by: novaraptor on June 09, 2014, 11:00:17 AM
thanks, I'll take a look there. There was an recent post about the choke assembly wearing and not fully closing. I'm just over 66k miles, and things do get worn...
