What is this loose cable?
I don't know what this cable is for. I cannot find it on the electrical schematic drawing.
Wire colors are BRN and BLK.
It is possible it is a trickle charger lead wire, but the prior owner did not mention that he added a trickle charger wire harness. I guess I could test that theory, but the bike is not here with me.
The bike as a 1989 FK1200 California
Thanks in advance.
(http://fjowners.com/gallery/7/3934_26_05_14_11_23_29.jpeg)
That is what is on my California edition 86'. It went to an electric valve that opened and closed for the charcoal-filled vapor-collecting canisters behind the oil cooler. It is switched with the ignition so it is a handy connection for accessories.
Yep...what he said.
My '92 has the same "connector to nowhere" and I pondered this for a while as well. Intended for California models, it's just just not used on the non-California models.
I use it as a switch to drive 2 relays. It is an ignition switched circuit and works great for that purpose.
Quote from: movenon on May 26, 2014, 02:00:45 PM
Just curious George. :lol: which 2 relays are you running off of it?
Quote from: giantkiller on May 26, 2014, 03:58:40 PM
Heated grips and driving lights (of which are not installed yet). When the ignition is off I want them both circuits off line.
The third relay is driven by my horn switch to the Hella horns.
(http://fjowners.com/gallery/6/1651_01_03_14_11_14_12.jpeg)
Super clean George, I want ride with you, but not park next to you.... :biggrin:
Quote from: FJmonkey on May 26, 2014, 05:02:43 PM
No need to worry, George just snuck in a picture of the avionics panel in an F16. :biggrin:
Since my bike is a California model, should this wire be plugged into the emissions device?
Quote from: CafeNervosa on May 26, 2014, 08:19:10 PM
Do you still have it?
George's picture also shows the "field wire" red connector that's being discussed elsewhere.
Quote from: FJ_Hooligan on May 26, 2014, 08:58:34 PM
And the field wire did suffer some over heating of the connector. When it is unplugged you can see the damage. I changed out the regulator to an external unit.
No real damage. Caught it before it was a problem because I installed a voltmeter in my panel last year and observed the charging voltage going up, I think it got to 15.2 volts when I changed out the regulator.
It's only clean because I can't ride it :lol: See you in a few days.
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Quote from: FJmonkey on May 26, 2014, 08:35:13 PM
Yes, I think the California emissions control is still installed. I have owned the bike for only a few months.
Quote from: CafeNervosa on June 06, 2014, 09:25:20 PM
Then why is it not connected to the valve? Do you still have two canisters mounted behind the oil cooler?
Yeah, you're going to want to remove those emissions parts.
When they fail you'll leak petrol all over your hot, running engine; trust, I just went through this.
