General Category => General Discussion => Topic started by: ribbert on April 30, 2014, 09:30:10 AM
Title: Braindragger
Post by: ribbert on April 30, 2014, 09:30:10 AM
We should be pleased with the standards we set here for maintenance. The following is from a Huyabusa (of all things) forum. There were no recriminations from fellow members, simply advice on chains.
I've always had a noise with my chain, but it goes away for a bit with lube.  So I thought that was the cure. No. It is not.
I have just over 19k on the chain and sprocket.  I looked just to see what was wrong today, and I see chipped toothed, rear sprocket, rollers on the chain cracked, rollers missing-ALOT, and even after the missing roller I saw the skinnier part chipped around it. surprise the chain has not yet snapped off there yet!!  Can't believe I made my 1270mi trip like that!  I am betting it has been this way for a while even before the trip because I had always had the same noise, but these days getting louder.
I will check kneedraggers.com and ronayers.com to see if there are cheap replacements
Title: Re: Braindragger
Post by: TexasDave on April 30, 2014, 09:49:50 AM
Picking my bike up in Spokane I only checked two things before I rode it to Randy's shop. Oil level was good and clean. Chain looked OK and tension was good. Randy pointed out the chain had some kinks in it. I purchased a quality chain from RPM. Inspecting the chain closely I could not even staighten the kinks out by hand. This is a chain that had been 120mph for a short period of time. I don't want to think about what would have happened if it had broke. Thank you Randy for a closer inpection than mine.  Dave
Post by: Country Joe on April 30, 2014, 12:11:41 PM
Quote from: ribbert on April 30, 2014, 09:30:10 AM
A perfect example of the saying "Ya can't fix stupid"
Post by: fj1289 on May 02, 2014, 02:06:48 PM
Quote from: Country Joe on April 30, 2014, 12:11:41 PM
But at least on occasion you can remove it from the gene pool!
Post by: FJmonkey on May 02, 2014, 07:32:11 PM
Quote from: fj1289 on May 02, 2014, 02:06:48 PM
Unfortunately, most of the time,  after it has children...  :mad:
