General Category => Yamaha FJ1100 / FJ1200 Running Problems => Topic started by: Brian on April 24, 2014, 06:34:29 PM
Title: NOISE COMING FROM MY 84 FJ
Post by: Brian on April 24, 2014, 06:34:29 PM
Gday Guys , i have just noticed a high pitched screaming coming from my bike while riding ,it comes & goes frequently  it sounds like its coming from the engine but when i pull clutch in it stays there until i roll down to about 10kph then stops suddenly ,now its gettin colder its happening more often this would have to be a wheel bearing wouldn't it ?
does anyone know the part number of front wheel bearings for fj1100 so i can purchase locally
& have them quickly ,i have the seals
any help much appreciated
cheers Brian
Title: Re: NOISE COMING FROM MY 84 FJ
Post by: Pat Conlon on April 24, 2014, 06:39:58 PM
Hey Brian, disconnect your speedo cable at the wheel and pull your speedo cable out of the sheath, hook it back up empty, go for a ride and see if the noise goes away....
You might have the Death Howl...
Post by: Tiger on April 24, 2014, 06:40:26 PM
 :hi: Disconnect your speedo cable and take your FJ for a wee spin around the block.......is the noise still there ?? or :scratch_one-s_head:
John.
Post by: oldktmdude on April 24, 2014, 06:41:26 PM
   G'day Brian, disconnect your speedo cable at the wheel and go for a test ride. Make sure that you tape the cable end so you don't loose the inner cable. Front end squealing or screaming noises are usually associated with the speedo. If it's still making the noise, check your wheel bearings.  Pete.
Post by: Tiger on April 24, 2014, 06:41:50 PM
 :lol: :rofl2: :rofl: Great minds think alike Pat/oldkt :good2:
John.
Post by: oldktmdude on April 24, 2014, 06:47:07 PM
      Seems like I'm about 3 or 4 minutes behind?  :unknown:  Pete.
Post by: Brian on April 24, 2014, 06:54:52 PM
WOW , unreal how you guys think alike ill get out of my Pyjammies & do that,
if that is it do i just grease the cable or is it the speedo drive or head then ?
thanks for everyones input
Post by: FJmonkey on April 24, 2014, 06:57:18 PM
Most likely the speedo, the scalded cat howl foretold the end of my 86' speedo. There is an outfit in San Diego, CA that repairs them. Or you could install a digital GPS unit, they look real slick...
Post by: Brian on April 24, 2014, 08:48:18 PM
Quote from: Pat Conlon on April 24, 2014, 06:39:58 PM
Yep u got rite guys, noise stopped when removed , rerouted cable & reconnected & noise gone (at the moment anyway) your all unreal
cheers Brian  :good2: :good:
Post by: oldktmdude on April 24, 2014, 09:00:16 PM
Quote from: Brian on April 24, 2014, 08:48:18 PM
Brian, the cable is probably due for some lubrication. Lithium grease seems to be a good way to go.
You wouldn't think such a wicked noise could come from a speedo cable.   Pete. :scratch_one-s_head:
Post by: simi_ed on April 24, 2014, 10:46:56 PM
Quote from: oldktmdude on April 24, 2014, 09:00:16 PM
Exactly, you'd never think a cable could make that much noise, cause IT CAN'T.  The howling gods have just been stirred about, they'll be back.  Don't delay, make plans to get it fixed bore it goes Tango Utah.
