General Category => Maintenance => Topic started by: Tex on March 30, 2014, 02:35:30 PM
Title: Fuel cap noise
Post by: Tex on March 30, 2014, 02:35:30 PM
Ok so when I run the FJ for awhile and I shut her off I get a whistling noise coming out of the fuel cap. Why is this happening. Thanks.
Scott
Title: Re: Fuel cap noise
Post by: Pat Conlon on March 30, 2014, 02:47:13 PM
That is a warning sign...Danger! You are using the wrong engine oil!
http://www.fjowners.com/index.php?topic=2024.0 (http://www.fjowners.com/index.php?topic=2024.0)
Post by: Tex on March 30, 2014, 02:56:56 PM
Pat what do you mean by this? How can oil be the cause?
Post by: Tex on March 30, 2014, 02:59:30 PM
Lol. Ok I get it. I think. I need to pull the cap and clean it
Correct? I didn't see the link at first. Do I need and parts to do this?
Post by: Tex on March 30, 2014, 03:18:40 PM
So from what I have read this is normal for the FJ correct? And leaving it alone is what I should do?
Scott
Post by: movenon on March 30, 2014, 03:19:24 PM
Quote from: Tex on March 30, 2014, 02:59:30 PM
No parts unless you loose something... I would just take it apart and try to clean up the insides and reassemble.  If it still sings, either get in harmony with it or remove the orange flapper.
I would try to keep the flapper in service because of the ethanol fuel we have.  Ethanol likes a closed system.  Alcohol likes to absorb water from free air.
Don't loose that little ball bearing and spring... Before you take it apart look at the small "L" bracket held on by one of the screws. Behind that bracket is the small spring and bearing.  Don't get the orange flapper in backwards either... Blow out the vent tube also.
Post by: Pat Conlon on March 30, 2014, 03:24:19 PM
I was teasing Tex.
A 'flapectomy' is what we call it, when we modify (via a notch) or remove those 2 salmon covered flaps in the gas cap.
That will allow the tank to vent without singing....However, some folks like the sound, to they leave it alone.
Your call... It's a very normal condition.
As George says, the spring and little ball tends to fly away, so if you do this mod, take the cap apart in a big Baggie or bucket.
