General Category => Maintenance => Topic started by: Tex on March 30, 2014, 12:17:50 PM
Title: RPM Pod filters
Post by: Tex on March 30, 2014, 12:17:50 PM
Hello All,
   I just purchased Randy's pod air filters. Hopefully I'll have them next week. Was just curious after putting them on do I have to make any adjustments to the carbs? Thanks
Scott
Title: Re: RPM Pod filters
Post by: Pat Conlon on March 30, 2014, 12:29:32 PM
Do you have a aftermarket exhaust system?
I recommend 117.5 mains, #40 pilots and shim the jet needles.
At the minimum, shim the jet needles. It's easy, you don't have to remove the carbs.
They are accessible from the top.
Post by: Tex on March 30, 2014, 12:35:02 PM
No I have stock exhaust. Ok how would you go about shimming the needles? Have not done this before. Thanks
Post by: FJscott on March 30, 2014, 12:56:43 PM
Quote from: Pat Conlon on March 30, 2014, 12:29:32 PM
what groove is the needle clip placed in when shimming the needle? I will be rejetting my Carbs when I get back and was curious about needle set up.
Scott
Post by: FJmonkey on March 30, 2014, 01:16:45 PM
If you have stock carbs then you will need to shim the needles up, raise them with a small (tiny) washer. However, if you stock exhaust, you may not need to shim them. The stock air box and exhaust are both flow restrictions. Both need to opened up before air flow is improved enough for needle changes. The #40 pilot is a change you can make anytime and enjoy an improvement. Aftermarket needles have additional grooves in them allowing for changes by moving the clip up or down in the grooves.
Post by: Tex on March 31, 2014, 10:54:25 PM
This might be a dumb question but Can you open up a stock exhaust?
Post by: X-Ray on April 01, 2014, 12:00:20 AM
I've got aftermarket cans on the FJ, and I thought I would have to change the carb settings a bit when I put on the Unifilters. But everything is sweet, no idling probs or hesitation etc. Of course this won't be the case for everyone.
Post by: racerrad8 on April 01, 2014, 10:39:43 AM
Quote from: Tex on March 31, 2014, 10:54:25 PM
Sure, you can knock the baffles out of the stock mufflers for a flow through system.
Tim, as I already stated in your other post about the needles, shoot me an email and I can get you dialed in on carbs.
Post by: fintip on April 01, 2014, 02:19:08 PM
Best just to get Randy's advice. He's literally built hundreds of sets of carbs.
But for what it's worth...
http://fjowners.wikidot.com/pods#toc2 (http://fjowners.wikidot.com/pods#toc2)
(notice that it says right there: best to talk to Randy.)
