General Category => Maintenance => Topic started by: europe50 on October 19, 2009, 12:53:43 PM
Title: Clutch lever pull distance...
Post by: europe50 on October 19, 2009, 12:53:43 PM
My '86 FJ 1200 has about 30k miles and runs great. but I don't really have to pull the clutch handle back more than 1/4" (With pressure) to shift gears. I currently do not have any slipping issues, so is this normal, or is my clutch going?
Title: Re: Clutch lever pull distance...
Post by: the fan on October 19, 2009, 03:40:13 PM
Dean N. had the same issue on his 93. When I checked it out he had several drive (fiber) plates that were worn beyond spec. Replacing the clutch discs solved the problem.
Post by: europe50 on October 19, 2009, 09:20:35 PM
Any good places to get good clutch discs? Any recommendations?
Post by: the fan on October 19, 2009, 09:29:24 PM
Gary McCoy of MonDak Motorsports in Sidney MT http://www.mondakmotorsports.com (http://www.mondakmotorsports.com) is the preferred USA source.
You need to look up your own part numbers, but his discount makes it worth the effort.
His email (preferred method of contact) is garymccoy@mondakmotorsports.com
Phone numbers are: My toll free # 866-433-6635 reg ph # 406-433-6635 fax 406-433-8337
So basically.
1) Look up your parts and email the list to garymccoy@mondakmotorsports.com .
2) include in the email that you are part of the FJ Owners group and your user name.
Gary will email you a quote with the correct pricing ASAP. Remember the correct pricing will not show up in the shopping cart if you use the Mondak sites order form. It's best just to email the list to Gary to avoid confusion.
Post by: racerrad8 on October 20, 2009, 03:00:07 AM
Quote from: europe50 on October 19, 2009, 09:20:35 PM
Raduechel Performance Motorsports
randy@rpmracingca.com
http://www.fjowners.com/index.php?topic=69.0 (http://www.fjowners.com/index.php?topic=69.0)
Also another post on this topic; http://www.fjowners.com/index.php?topic=1014.msg7367#msg7367 (http://www.fjowners.com/index.php?topic=1014.msg7367#msg7367)
Post by: europe50 on October 20, 2009, 07:52:17 AM
It sounds like I need a couple of fiber discs. Thanks guys!
Post by: wheels on November 24, 2009, 12:31:38 AM
hi europe50 i was wondering if changing the clutch plates solved your problem and if so were the plate's worn .? for i stick my bike into gear and let the clutch out and there's nothing. ican rev it up and the wheel just spin's slowly any idea's cheers wheels.
Post by: europe50 on November 27, 2009, 10:46:40 PM
I plan on checking on my clutch in the near future (During winter) and can give you an update then. Just trying to get as much riding as I can before packing it up.
Post by: indyblue on December 08, 2009, 10:11:18 AM
Isn't it recommended to replace the fiber friction disks and metal clutch plates at the same time?  Or is that a judgment call depending on condition of the plates?  On my cars I always replace brake pads, wheel bearings, etc. in matched sets as good practice.
Post by: andyb on December 08, 2009, 01:29:09 PM
Judgement call there.
If the steels are not warped and not missing bits, use them.  Discoloration is ok.
