General Category => Maintenance => Topic started by: keand3 on January 26, 2014, 03:26:26 AM
Title: Brake caliper bolts
Post by: keand3 on January 26, 2014, 03:26:26 AM
Hi guys
I was looking at et parts microfiche for my 86 1200 to identify the bolt size on my calipers. (front and back are the same)
I will be replacing the rear ones since the are full of rust, and the threads are worn.
But i would like to het it from someone how knows the size.
I get the size M10x308mm from the microfiche. Isen't 308mm i length a wird figuer or is it just me?
Ken
Title: Re: Brake caliper bolts
Post by: keand3 on January 26, 2014, 04:00:03 AM
I figured it out.
The bolt is 40mm in total length. 308mm is just the aera where the threads is..
Ken
Post by: simi_ed on January 26, 2014, 04:26:01 AM
Ken, if you're buying bolts, get the bolts from the YZ750, they're hollow, saving a bit of unsprung weight.  Yami p/n 90105-10725-00 BOLT,WASHER BASED.  Also, the stock FJ bolts seem to have gone obsolete.
Post by: keand3 on January 26, 2014, 06:35:26 AM
Quote from: simi_ed on January 26, 2014, 04:26:01 AM
Thanks, I will check them out. I was thinking of ordering new bolts from http://www.pro-bolt.com/ (http://www.pro-bolt.com/)
Have used them before but they are a bit expencive. But they deliver perfect quailty.
Ken
Post by: FJmonkey on January 26, 2014, 04:27:18 PM
Trust Ed, he is an expert on hollow....  :sarcastic: :sarcastic: :sarcastic:
