General Category => Maintenance => Topic started by: Tom on December 20, 2013, 04:16:26 AM
Title: Front end
Post by: Tom on December 20, 2013, 04:16:26 AM
Well, fitted the new RPM fork valves and springs to compliment the RPM rear shock. Also fitted a CBR1000 radial master cylinder and braided lines. So now not only does the FJ glide beautifully over the rough stuff, I can confidently scrape the pegs, it also stops with one finger!!!!! Now for some stickier tyres I think!
Thanks Randy  :::::)))))
Title: Re: Front end
Post by: Bones on December 20, 2013, 05:09:15 AM
Sounds like you've got it sorted suspension and brake wise Tom, what other mods have you done, or got planned for the future.
Post by: Tom on December 21, 2013, 10:11:07 PM
Quote from: Bones on December 20, 2013, 05:09:15 AM
Basically I am keeping it standard. Keeping the 16/17 inch wheels, probably fit Bridgestone BT45s. It has an Rpm spin on filter(I use a Subaru filter which works fine) No air box, dual pod air filters, (rejetted and fiddled with using a CO2 meter and vacuum gauges, Also I have access to a dyno - yet to do. I can just let the clutch out two up and it'll rev cleanly to 9K, with no surging at cruise, so it can't be too far off- Grunt, yeah!! It has no brand noisy mufflers which I want to change to something a bit quieter and find a nice rack (which my missess has, but not very useful for keeping people on the back!!)
Post by: movenon on December 21, 2013, 10:17:11 PM
You might be able to repack your mufflers.  :good2:
Post by: Tom on December 21, 2013, 10:49:34 PM
Quote from: movenon on December 21, 2013, 10:17:11 PM
This is true, but really I'm not keen on how they look either and working in a bike shop, new ones are easy to come by.. :good2:
Post by: movenon on December 22, 2013, 01:22:39 AM
Quote from: Tom on December 21, 2013, 10:49:34 PM
I try to stay away from the bike shops.... makes want stuff :good2: :good2: :lol:
Post by: dayta on December 22, 2013, 03:53:31 AM
Hi tom,
      Can I ask what weight springs you have run in your front forks??
I am running .9 in mine and they feel to hard..
Post by: Tom on December 22, 2013, 04:27:07 AM
Quote from: dayta on December 22, 2013, 03:53:31 AM
Hi tom,
I weight in at 75kgs so I am running .80 springs with preload adjuster backed off fully, 30mm sag and 130mm air gap with the RPM valves in. This is OK with a pillion on the back too, a little soft under braking, but I mainly ride with no pillion. The shock is as Randy sent it to me? Spring preload is approx 20-25% wound up by the look of it and works beautifully with just me, not to bad with a pillion, you just need to back off the throttle a bit.
