General Category => Modifications => Topic started by: DreadRock on October 08, 2013, 11:49:13 AM
Title: 85 FJ1100 Mirror Fix !!
Post by: DreadRock on October 08, 2013, 11:49:13 AM
  Been slowly updating my 85 FJ1100 lil at a time thanks to you guys and i couldnt be more happy with it so far  :good2: So i was wanting to change the mirrors on it as i dont like the stock placement of the mirrors. After reading what alot of guys did to the 1200 mirrors i thought i would give it a try as i couldnt find much on a 1100 fix .
  So i started out with aftermarket CBR1000rr mirrors that where cheap to just see what i can come up with  :unknown: Well with the 1100 there mounted on the levers not the fairing which i dont like so had to figure how to mount them with out messing up the fairing . So pulled the fairing off and the cluster out to have a look ! Thought i could use the first two holes where the windscreen bolts are and add Alum back plates with expoy to keep it firm . After picking up some Alum and doing some cutting and shapeing got them mounted and well they looked ok and strong BUT just did not like the look or angle . Also couldnt get the Alum thin enough to get a good clamp down on the mirrors them self  :negative:
  So then did some talking and reading and looking and found what i hoped would work ! Well found the a SV1000 had what i needed and might just be the fix ,so called on local bike salvage and found a good set i think are off the SV but not sure . Am sure the mounts are the same so for 20 bucks for good OEM mirrors i was game !  :good2: Well with lil work they fit PERFECT  :drinks: Only thing i had to do was drill ( very hard to do ) one hole for mounting but couldnt be happier about it ! Took the bike out over the weekend and they work great very lil vibration at 100mph do should be good to go ! Next will be updating frontend forks,wheel,brake and update rear wheel ,brakes !
  Here are a few pics on the project ...
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM_zpsee1438b7.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM_zpsee1438b7.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM9_zps7b5ac555.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM9_zps7b5ac555.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM8_zps887e08a3.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM8_zps887e08a3.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM7_zps88eb17af.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM7_zps88eb17af.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM6_zpse36aaf00.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM6_zpse36aaf00.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM5_zpsdd59e16a.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM5_zpsdd59e16a.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM2_zpsa65c5e9a.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM2_zpsa65c5e9a.jpg.html)
(http://i1104.photobucket.com/albums/h331/dreadrock1/FJM4_zps7d81edca.jpg) (http://s1104.photobucket.com/user/dreadrock1/media/FJM4_zps7d81edca.jpg.html)
Title: Re: 85 FJ1100 Mirror Fix !!
Post by: FJ_Hooligan on October 08, 2013, 11:55:19 AM
So is there anything reinforcing the fairing on the backside of the mount?
Post by: DreadRock on October 08, 2013, 12:32:19 PM
Quote from: FJ_Hooligan on October 08, 2013, 11:55:19 AM
Yes I have Aluminum stock behind fairing the bolts go thru that are Epoxy in place to spead the load over bigger area !
Post by: DreadRock on October 22, 2013, 08:30:10 AM
  Update on mirror fix: Did a 800+ mile ride over the weekend and have to say the mirrors work out great . Had good view around my arms and was at ever speed from city to highway speeds and couldnt be more happy with it !  :yahoo:
