General Category => Maintenance => Topic started by: chiz on September 26, 2013, 01:51:33 PM
Title: Did I do this correctly
Post by: chiz on September 26, 2013, 01:51:33 PM
Happy Thursday all
Just moved my ignition plate slightly clockwise on my 84 and was not sure if I should have gone the other way. Moved it about 2 to 3 mm. Notice what might be a bit more buzz at the foot rests otherwise I am not sure what was accomplished.... Also what is the generally accepted idle speed for a stock bike I guess mine is around 5 to 7 hundred. There is a bit of top end clatter at this rpm nothing like my R3 for sure, I can make it go away if the rev's are turned up a bit. Folks at work say it is noisy mechanically but I don't think they have heard or remember what a big air cooled engine sounds like or how noisy comparatively speaking it is to water cooling
     Chiz
Title: Re: Did I do this correctly
Post by: FJmonkey on September 26, 2013, 02:11:55 PM
Idle should be around 1100, it will take some of the chain slap noise out.
Post by: chiz on September 26, 2013, 02:15:25 PM
OK good thanks, what about the ignition plate trick did I go the right way?
Chiz
Post by: racerrad8 on September 26, 2013, 02:21:15 PM
That is correct and the idle speed should be 1100 rpm and a lot of the chain noise will go away.
Post by: FJmonkey on September 26, 2013, 02:35:20 PM
Clockwise is correct.
