What is the possible cause of popping when bike is being revved up?
I've got a few issues with my bike that I hope I get answers to at the fj clinic Saturday.
I'm pretty sure I will be needing carbs done or new carbs.
When I fire up and run choke I get popping....soon as I kill choke no pops anymore.
Ummmm.... Need more info on when the popping happens. Acceleration, deceleration, idle. Is the engine warm, cold, choke on/off? Do you wear boxers or tightly-whities?... Sorry, strike that, wrong forum.... :blush: What are the conditions of the engine when this is happening?
Vacuum leak.
Boxers only and im thinking my issue is more complex as I went to check on my bike this morning and there was a small puddle of gas under carbs.
Rebuild the carbs (using the magic screw kit from RPM) and all will be healed.
Quote from: fuel80guy on September 05, 2013, 06:31:53 PM
Quote from: fuel80guy on September 06, 2013, 08:12:16 AM
...im thinking my issue is more complex as I went to check on my bike this morning and there was a small puddle of gas under carbs.
As recommended a while back...
There are also a couple of recent carb stories as well.
Quote from: fuel80guy on September 14, 2012, 11:33:34 AM
Im looking to buy a 1988 fj1200.
This bike runs but needs the carbs rebuilt and ive been quoted $500.00 to rebuild carbs.
Are there new carbs available for this bike or is it as easy as me unbolting carbs and sending to somebody to rebuild?
Yes im a a newbie so id appreciate any help at robwi@sympatico.ca
Thanks Rob
Quote from: 1tinindian on September 14, 2012, 12:40:09 PM
Unbolt and send to Randy @ RPM
http://www.rpmracingca.com/ (http://www.rpmracingca.com/)
That is just what I did this spring and found it to be the right thing to do with great results.
Sent RPM Randy the carbs... (http://www.fjowners.com/index.php?topic=10053.msg96434#msg96434)
Randy Raduechel is The Man (http://www.fjowners.com/index.php?topic=10117.msg97161#msg97161)
