http://www.ebay.com/itm/VMS-Motorsports-Legends-Race-Car-FJ1200-1250-Complete-Top-End-Oiler-Assembly-Kit-/231033519489?vxp=mtr
I think it doesn´t fit due to the frame main rails, does it?
not gonna happen................
Those elbow fittings definitely will not fit in an FJ frame. And the mod is not needed on a bike anyway - they get plenty of oil to the cams when used for the designed purpose -- delivering kookaloo in a motorcycle!
IF for some reason you really wanted to do it - that is not the way! The oil from that galley is not filtered.
I added a filter in line when I did the dragbike. Using the after market cast big block I had a lot of issues with oil leaks - so I "dry blocked" it. Had to use low profile banjo bolts and had to narrow the banjo fitting slightly. Even then had to grind down a wrench to fit between the frame to tighten it up a hair when it seeped at first.
NOT worth the headache to do on a bike!
Thanks for your info. I know the mod is not necessary, but the look say: "its tricky" and it is another gadget :gamer:
